587,611 active members*
3,824 visitors online*
    Oct 2008
    2100
    Hurcu KM Quill
    I am trying to disassemble a Hurco quill to at a minimum regrease the bearings, and maybe to replace them. For the life of me I can't get the retainer in the nose or the nut on the top to move.
    I found one little set screw that appeared to be holding the retainer. It has been removed.
    There was one locking tab that appeared to be holding the nut. It has been folded flat.
    Now what?
    Bob La Londe
    http://www.YumaBassMan.com
    Oct 2008
    2100
    Re: Hurcu KM Quill
    The rear nut is out with use of penetrating oil, and a drift. Even after soaking for an hour it took a couple pretty healthy whacks with a 16oz persuader to get it free. From what I have found so far I think that nut may have been over tightened.
    The front retainer is still firmly in place. I'm going to put it in a plastic bag, spray a bunch of penetrating oil in there, and leave it over night. Its a trick I have used before for things that are hard to "soak".
    Bob La Londe
    Oct 2008
    2100
    Re: Hurcu KM Quill
    I made a spanner, and got the spindle nose retainer off. Today I pressed
    all the bearings off/out and took a look.
    I have not washed the grease and dirt out of the bearings, but one of the
    ACBs doesn't feel wonderful to me. I figured as long as I have it apart I
    might as well replace all the bearings if they don't cost to much.
    On the back its got a Fafnir 206PP. Seems to be pretty easy to find.
    On the nose its got a pair of New Departure 20207 ACBs. Those also seem to
    be modestly easy to find. What got me is they don't seem to be a matched
    set or anything. There are no alignment marks and they are both marked
    identically. They are just back to back against the spacers.
    It does have both inner race and outer race spacers between the ACBs and an
    inner race spacer between the ACBs and the rear bearing so preload is pretty
    much predetermined.
    None of these bearings are particularly expensive. Seem like an off the
    shelf bearing, although most I found are new old stock rather than new
    stock.
    Am I missing something? Is it really just as simple as it seems? Just buy
    a couple New Departure 20207s and a Fafnir 206PP and press all the new parts
    back in place?
    Bob La Londe
    15362
    Re: Hurcu KM Quill
    Quote Originally Posted by Bob La Londe View Post
    Am I missing something? Is it really just as simple as it seems? Just buy a couple New Departure 20207s and a Fafnir 206PP and press all the new parts
    back in place?
    New Departure went out of business in the 1990s,
    Your Bearings should be a 30deg AC bearing Matched Pair, for Back to Back mounting
    You may be missing some letter or other numbers, unless someone changed them for a standard C3 Bearing which is no good for a spindle bearing
    This is some other bearing manufacturers numbers they are normally an ABEC7 Grade, & are not cheap, if you find a low cost for these Bearings, then you have the wrong Bearings
    7213ATDC9-P5
    Barden 207HDL
    The top Bearing is a standard Deep Grove Ball Bearing sealed 206-2RS this grade is a C3
    Mactec54
  1. Quill bearings, etc.
    By jason_b in forum Charter Oak Automation Support Forum
    Last Post: 10-20-2012, 11:36 PM
  2. RF-45 Quill DRO
    By Speed57 in forum Benchtop Machines
    Last Post: 10-07-2012, 03:17 AM
  3. DRO on the Quill
    By ajclay in forum Bridgeport / Hardinge Mills
    Last Post: 04-12-2012, 12:48 AM
  4. Quill Stop
    By slucas_clmach in forum Want To Buy...Need help!
    Last Post: 07-22-2009, 02:08 PM
  5. Quill removal
    By HOSS in forum Tree
    Last Post: 08-08-2006, 12:21 PM
