Re: Picking Fixture Coordinate Origin Locations
Originally Posted by
amish_rabbi
is there any reason to not use the following strategies?
I usually do exactly as you have said.... but...
If I have a double sided part, and am not using a fixture plate, I keep the X,Y coordinates at the same location on the part.
IE, origin starts at left back corner of part (which coincidently is usually left front corner of fixed jaw). (z axis on surface of part)
When I flip it (long end for long end), the X,Y coordinate is now right back corner of part (z axis on new surface of part).
This elements any possibility of the stock being a different length than what I modeled as my stock in HSMWorks from causing the second side cut from not lining up with the first side.
It is embarrassing when you modeled at 6" long chunk of stock IN CAM when you generated g-code, but you were lazy and used a 6.3" piece of stock without cutting it to size. If I kept the coordinate at the left front corner of the fixed jaw of the vise, the second cut would be misaligned by 0.3".
Clear as mud?
If I have a fixture plate that lines the part up on both sides, than I x,y,z off the fixture plate back left corner as previously discussed.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
