603,978 active members*
2,418 visitors online*
Results 1 to 2 of 2
    Jul 2015
    No communication?
    Hello CNC Zone, I am a brand new user and am searching for some help in making the mill talk to the computer. I am using a vertical machining center 15 made in 1994 by Fadal I'm guessing. My boss said he has been using a program called terminal to send and receive files, and for some reason I cant seem to figure out how it works. I have read and tried everything in the manuals. Is there an issue with the computer or program?
    Oct 2013
    64
    Re: No communication?
    Your boss could probably show you how to check the settings such as baud rate, handshaking, and a few others on the machine and computer program to make sure they are the same. A call to Fadal or whoever makes the terminal program may yield some info as well. Good luck.
  1. ip/tcp vs. com communication
    By Rylee in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-07-2011, 08:11 PM
  2. Communication
    By neilthib in forum Fadal
    Last Post: 12-13-2010, 09:27 PM
  3. Need help with communication.
    By AceikTool in forum EDM Discussion General Topics
    Last Post: 09-30-2008, 07:33 AM
  4. PC<->NC communication
    By loky in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2007, 09:44 AM
