587,204 active members*
2,999 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Help with determining vacuum pump suitability
Results 1 to 2 of 2
    Jul 2013
    27
    Hello!
    First off, sorry for posting this here, I just couldn't find an appropriate forum for this question. Perhaps a mod can move it?
    I am looking to purchase a vacuum pump for a small vacuum chuck I have designed.
    Currently I am looking at this pump.
    I have attahced the vacuum chuck in solidworks format, but I will provide what I think are the necessary calculations below.
    The vacuum:
    - 3.15 CFM
    - 24" Hg
    The chuck:
    - Total area where air can pass from the chuck to the vacuum (holes on the top holding the part): 3.730688in2
    - Tube coupling (holes between part and vacuum, to couple the hoses to the chuck: 0.192in2
    What I am worried about (but do not know how to determine) is that the chuck is actually too small (restrictive?) for the pump, and that the pump will heat up or become damaged. Sort of like a blocked vacuum cleaner,
    Apr 2004
    733
    Re: Help with determining vacuum pump suitability
    I have similar pump that I use for vacuum veneering. As far as I know that pump is continuous duty and will be fine even if you block the inlet for extended time. The fan cools the motor and if it does overheat there is a over temp switch. I have left mine on over night with no problems.
    A standard vacuum cleaner will overheat if blocked because it uses the exhaust air to cool down the motor. Vacuum pump has a built in fan to cool.
  1. Vacuum Pump Help!
    By P dogg in forum Multicam Machines
    Last Post: 07-30-2015, 12:19 AM
  2. Vacuum pump size for vacuum hold down jig?
    By dawgwalker in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-21-2014, 03:07 AM
  3. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  4. Vacuum Pump
    By ranchak in forum Moldmaking
    Last Post: 10-26-2009, 06:13 PM
  5. Where to get a vacuum pump
    By whiteriver in forum DIY CNC Router Table Machines
    Last Post: 05-11-2004, 04:47 PM
