603,800 active members*
3,699 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Small Slitting Saw or Small Woodruff Cutter
    Feb 2006
    7063
    Does anyone know a source for either small diameter slittlng saw blades, or large diameter Woodruff cutters? Seems like all the slitting saws I can find are 2.75" or more in diameter, with 1" center holes. All the Woodruff cutters I can find are rather small diameter. Ideally, I'd like something that would allow me to make about a 3/4" under-cut in a part - perhaps a 2" maximum diameter cutter. A slitting saw does the job nicely, but requires a huge amount of clearance around the part, making a multi-part fixture far larger than it would otherwise be.
    Regards,
    Ray L.
    Re: Small Slitting Saw or Small Woodruff Cutter
    Quote Originally Posted by SCzEngrgGroup View Post
    Regards,
    Ray L.
    Tormach has slitting saws that are 2" in diameter. They also have arbors for them
    34394 - HSS Slitting Saw: 2" x 1/16" x 1/2" x 28T
    32430 - TTS 0.5" Saw Arbor
    Jul 2008
    13
    The arbor is a Taig, 1/2" dia. x 3/8" shank. Not sure where I got the cutters from (Ebay?) but these guys have some:
    High Speed Steel Plain Metal Slitting Saws Malco Saw Company
    Attachment 283816
    Joe
    Feb 2006
    7063
    Perfect! Thanks guys!
    Regards,
    Ray L.
  1. PLEASE HELP: Need small shank woodruff
    By declanhalpin in forum MetalWork Discussion
    Last Post: 05-19-2011, 11:58 PM
  2. Wanted - small slitting saw blades
    By watchman in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 03-14-2008, 08:17 PM
  3. Very Small cutter
    By djh82uk in forum Hobby Discussion
    Last Post: 09-23-2007, 07:31 PM
  4. Madcam 2 cutter too small
    By baldysm in forum MadCAM
    Last Post: 07-26-2007, 08:16 PM
