I need a industrial switch or hub (unmanaged) with good shielding to be installed in a control panel. The environment is a typical clean panel. Does anyone have any recommendations with a price tag under $200. (at least 4 port)
If 10mbit will work I have an old IBM one with a solid alum. case. You pay shipping it's yours. 12 port I believe. Can send a picture and measure size if it might work for you.
Hirschmann Spider5TX
MOXA EDS-205
Weidmuller 8808230000
All are 5 port unmanaged switches. Not sure about the Hirschmann, but the others should be about $130. I think all are 24VDC with redundant power inputs.
CP
No thanks on the used one but thanks for the offer. We're a oem and can't sell machines with used parts if you get my drift. And, I'll check those others out.
Thanks.
Thanks.
