603,795 active members*
2,772 visitors online*
Results 1 to 7 of 7
    Feb 2007
    1538
    Canned Cycles in Pathpilot
    Hi Folks.
    I have a complex 3D shape I want to mill on the 4th axis in 6 x 60 deg settings.
    I have in the past just copied and pasted the code - with the different A position aftereach section of code. But I would like a more elegant and quicker process.
    I see in the Tormach operator manual page 112 - the A axis is not allowed to move as part of a canned cycle - does this mean it cannot be used in Pathpilot or am I misunderstanding this?
    If so, is there another way to command a A move increment, and then return to top of programme?
    Cheers Keen
    Feb 2008
    644
    Re: Canned Cycles in Pathpilot
    What about calling a subroutine with a 'A' parameter 6 times?
    Feb 2007
    1538
    Quote Originally Posted by PCW_MESA View Post
    As I said - page 112 seems to preclude this.
    "I see in the Tormach operator manual page 112 - the A axis is not allowed to move as part of a canned cycle - does this mean it cannot be used in Pathpilot or am I misunderstanding this?"
    Keen
    Apr 2013
    1780
    I'm confused. I believe that the canned cycles being discussed on page 112 are G81, G82 and G83 (drilling). Do you actually want to turn the A-axis between pecks?
    Feb 2008
    644
    A subroutine is not a canned cycle
    In fact, I think you can put subroutine with a "A" parameter in a
    do/while loop and have a very compact repeated 3D profile
    with A Indexed between profile passes
    Feb 2007
    1538
    My apologies. I usually use my CAM programme to generate code and so my understanding of hand coding is limited.
    Thanks PCW-Mesa for pointing out that a sub routine is not a canned cycle. I am studying it now and will try it out on my A axis job.
    keen
    Feb 2007
    1538
    Thanks for you help guys.
    keen
  1. canned cycles
    By larrygk in forum Mastercam
    Last Post: 01-31-2011, 07:34 PM
  2. G91 in canned cycles
    By Ashish B in forum CNC Machining Centers
    Last Post: 05-23-2010, 04:12 AM
  3. canned cycles
    By astro cnc in forum G-Code Programing
    Last Post: 02-17-2009, 03:40 PM
  4. canned cycles on 16t?
    By DocHod in forum Fanuc
    Last Post: 07-09-2007, 01:58 AM
  5. G90/G91 in canned cycles
    By alfalfa in forum CamSoft Products
    Last Post: 02-25-2007, 12:20 PM
