588,033 active members*
5,335 visitors online*
IndustryArena Forum > Community Club House > Sears pro band saw. Problem !!! Alaska, Fairbanks Area
Results 1 to 5 of 5
    Dec 2006
    3
    Question Sears pro band saw. Problem !!! Alaska, Fairbanks Area
    Can anyone tell me what blade comes with the band saw??? out of the box from sears. I am looking for some help using my new equipment. I took a ruler and it seems to have 7 tpi. I cant tell if its for steel or wood I need to use this band saw for mild steel .
    35538
    What type of saw is it. A wood cutting bandsaw?
    Dec 2006
    3
    Exclamation sears band saw
    Sears 14 in pro band saw .
    Mar 2004
    564
    Is this the make/model? (see link below) looks like you can buy 3 pc blade set. the blade it comes with is good for wood and mild steel according to the description.
    xxx.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00929365000&cat=Power+Tool+Accessories&subcat=Blades
    menomana
    Dec 2006
    3
    Thanks.
