603,850 active members*
3,535 visitors online*
Results 1 to 3 of 3
    Feb 2016
    14
    touch n go Z switch not working
    Almost have this thing operational. I have the touch and go plate from shopdroids with a z switch. When I press the Z switch, the light on the table i/o card lights up but anytime the z tries to zero, the motor keeps going where I have to e stop the machine. Since the board lights up, i assume it is a setting I dont have correct. Any idea what is happening? If more info is required, Ill post back asap.
    Gecko G540 motors with Gecko interface
    MP3000 with DTHCIV from CANDCNC
    running mach3 and sheetcam
    Feb 2016
    14
    Re: touch n go Z switch not working
    Also running a new hypertherm 65 with machine torch connected to the dthc through the specific cable(mic-01 i think) for that machine.
    Feb 2016
    14
    Got everything going and tested. Ill finish the post so when it comes up in the search engine it wont be a useless thread.
    All i did was set the z home and probe to enabled in ports and pins, emulated the z home and all is well. Also, I had to change my switch to normally open but i think i could have changed a setting to achieve the same thing. Maybe this will help someone.
  1. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  2. touch off stopped working?
    By BrainFried in forum LinuxCNC (formerly EMC2)
    Last Post: 06-25-2015, 12:23 AM
  3. 2 pole limit switch wiring for floating Z axis touch-n-go.
    By greenjeens in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-11-2013, 09:21 AM
  4. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  5. thc touch off and switch travel
    By elgonzo in forum Mach Plasma / Laser
    Last Post: 08-01-2009, 08:22 PM
