... ok.. i just spent almost two days trying to cut a simple groove in a part on my QS 30 with a T4.
Im not an expert in mazak programming but am able to do most. Made grooves before altho always seems like a challenge.
Here it is:
a .472 wide wide with an R.234 at the bottom ( an o-ring groove in a sence)
.197 away from the face starting at 7.283 dia and ending at 6.811 dia
Using a GROOVE OUT (blind , or closed ) option with trapezoid profile option, x starting point of 7.283, z starting point od .197, x finish point of 6.811 and z finish point of .197 with a end R of .234
Im using a sandvik 6mm round insert holder and use GROOVE OUT tool geometry with .236 cutter width and a R.118 tool tip.
Theoretically (as far as underestand) Mazatrol will automatically compensate for the TTR ( which is the best feature of mazak for me) and since the insert R is smaller than the part profile it should work - right?
Well nomatter what i do it gives me an "invalid tool width in groove" error message.
I tried to foul the controll by changing the tool widths and insert radiuses to smaller once and - for the most part - it will work in "figure check" but not in simulation or auto run....
What am i doing wrong.....ma interpreting something incorrectly?
