I have a huanyang gt series gt-011g-2 VFD
It has auto tune but it either blow a fuse when i try and run it or trips the vfd
Spindle makes a ruff sound on starting before it trips.
I toned out the spindle wiring and installed a different brand that i am replacing because its underpowered, It works just fine.
My spindle is a vevor 7.5Kw or 10HP
Plate Info
300Hz
RPM 18000
KW 7.5
AMP 15
On the programming it said to enter this data from spindle from plate
P2.01 Motor Power i put in 7.5
P2.02 Motor frequency (It will only go from range 0-50hz) I put in 50
P2.03 Motor speed 18000 is what i put in
P2.04 motor voltage 380 also tried 240V as well
P2.05 motor amp 15
It then says run auto tune P0.16 (option 1) then run
I also tried manually entering this data Is 300mhz on 50hz?
P0.03 I Set to 300
P0.04 I Set to 300
P0.06 I Set to 300
P2.02 I set to 300
Still blows fuse
What programming am I doing wrong?
Here is the manual for the huanyang GT series that i cant get to work!!!!.
https://www.automationtechnologiesin...ies-manual.pdf
Old manual differant vfd
I also included the VFD manual that does work if you want to look at those settings.
https://www.et.byu.edu/~sorensen/A2%20VFD%20Manual.pdf
Thank you for any advice.
