Hi Everybody,
I attached the 4 rotary axis on my CNC router. Before, on the 3 axis system was easy but now I have some problems.
I'm trying to do a test part to be able to learn new skills. I will attach a picture with my part model.
Doing the finish cut in Mastercam is easy using Rotary 4ax. The problem I am having is I don't see a multiaxis roughing routine and I need to to remove as much stock as I can using a end mil before doing the finish with a ball nose.
Which is the better way to that?
Thank you!
