587,884 active members*
3,767 visitors online*
Results 1 to 5 of 5
    Mar 2007
    11
    Question wire offset values
    Hi all can anyone assist with a question about the wire offset values when setting up the eroder (fanuc tape cut model h).I'm pretty new to these machines and alot of knowledge and paperwork has been lost over the years,i need to know if there is some sort of chart or equation to work out the offset/compensation of the wire compared with the material and thickness
    Many thanks
    Stevatome
    Mar 2007
    11
    Unhappy offset values
    Does anyone know what i need please?
    Feb 2007
    4
    What type of material are you cutting, how thick is the material, what is your wire diameter, and what is your wire material?
    How many cuts are you making?
    A good starting point for 1 rough cut and 2 skim cuts would most likely be
    .008 offset as a 1st cut, .006 as a 2nd cut, and .0055 as a 3rd cut. Of course, you'll want to do some test cuts.
    BTW, that's using .010 wire
    Hope this helps
    Mar 2007
    11
    Cheers Bertram
    I am using 0.3 wire and material of various type and thickness i just wondered if there was some sort of rule of thumb for working out the parameters or is it just trial and error
    thanks
    stevatome
    Feb 2007
    4
    It's some trial and error. However, I would think that those offsets are a good place to start with that diameter wire. You're most likely going to have to do some test cuts, because your power supply I'm sure is different than mine.
    It also depends on how many cuts you are making. If you are only making 2 cuts, then I might start with .0071 and .0055.
  1. Fanuc non tape modes
    By 262 in forum Fanuc
    Last Post: 11-28-2010, 02:49 AM
  2. Fanuc tape reader
    By simoj in forum Fanuc
    Last Post: 09-13-2006, 07:46 AM
  3. FANUC TAPE CUT model D - HELP
    By promech in forum Fanuc
    Last Post: 06-13-2006, 07:56 AM
  4. Fanuc tape-cut seria D
    By promech in forum Waterjet General Topics
    Last Post: 06-12-2006, 09:34 AM
  5. Fanuc tape mode
    By mroy0404 in forum Fanuc
    Last Post: 03-17-2005, 10:15 PM
