587,675 active members*
3,943 visitors online*
Results 1 to 7 of 7
    Apr 2013
    Prototrak Plus manual
    Newbe here....I just got my first CNC milling machine. A Prototrak Plus.... I have no idea how to program this machine. Does anyone have a operators, programers manual ? I tried the manufacturer and was told it was out of print.
    JOHN
    Apr 2007
    45
    Did you find a manual yet? I look to see if I still have one.
    Bill K
    Jan 2014
    20
    Re: Prototrak Plus manual
    Any luck on the manual? I also have a prototrak plus and could use a programming manual.
    Apr 2007
    45
    Simracn,
    I'm sure I could find a manual, scan it and send it to you..... BUT where are YOU. Nothing in you profile for location.
    Not in USA....... = NOT getting copy of manual.
    Try Amazon or ebay. they have them.
    Bill K
    Jan 2014
    20
    Hello Bill, am down in the middle of Fl. But have been dealing with SWI on making sure my Y axis fault is the servo amp module. So far everything is pointing towards that. And sounds like the plus may not be supported much longer... sigh. But did find out that the newer X axis brg housing with a bit of a mod to the bearing race and taking off matl on the mach side, it works great :-)
    The Guy in Tech have been working with found one and sent me a PDF of it, so I was able to acquire a copy, thank you though for checking! And now if someone else needs a copy, may be able to work a help out.
    Thank you again! much appreciated even if you didn't have to send one :-)
    May 2018
    4
    Here is a link to the ProtoTRAK Plus Manual.
    https://www.dropbox.com/s/2evbiq0igi...0Plus.pdf?dl=0
    Here is a link to a ProtoTRAK Plus folder with other manuals and some programming sheets to use.
    https://www.dropbox.com/sh/26r0c8fth...2977YO02a?dl=0
    Jan 2014
    20
    Quote Originally Posted by Xuron View Post
    Thank you! and hope it can help others out as well. I do have our Enroute 5 and 6 sending post processing, so can send code and upload to our machine. Once I changed out the main board all has been working great.
  1. ProtoTRAK Plus programming manual
    By JohnT-cen in forum Machinery Manuals / Brochures
    Last Post: 06-19-2018, 03:42 PM
  2. Prototrak Plus controller manual
    By BlackbirdMFG in forum CNC Machine Related Electronics
    Last Post: 06-19-2018, 03:35 PM
  3. WTB ProtoTRAK PLUS or ProtoTRAK EDGE comtroller
    By LMSC in forum Want To Buy...Need help!
    Last Post: 12-31-2012, 06:15 AM
  4. Replies: 2
    Last Post: 10-30-2008, 04:19 PM
  5. Replies: 0
    Last Post: 10-25-2008, 01:03 AM
