603,388 active members*
2,701 visitors online*
Results 1 to 2 of 2
    Apr 2007
    68
    Can't get water to flow to Spindle
    Hello...Tool changer froze on columbo spindle. I have a g-penny water cooled spindle connected and so far, it works really well. The problem I'm having is I can't get the water to flow through the 1/4 hose consistently. I have tried 3 pumps ,the last being a 1/6 hp sump pump. I get small trickles and sometime a good stream then slowly stops. Nothing is clogged or kinked,. I have checked it thoroughly. It seems like as the water gets warmer it just peters out. The last pump I tried, heated the water up just cooling its motor! Any Ideas??? oh...this is a 4896 machine and each section of hose is around 30 feet long.
    Nov 2011
    480
    Re: Can't get water to flow to Spindle
    This may be due to the blockage of the spindle's water circuit. You can first suspend the operation of the equipment, and then repeatedly dredge the circulating cooling water circuit. After the dredging is completed, replace the circulating cooling water (pure water or distilled water) of the engraving machine spindle chiller. Filter impurities in the water while scale is generated to ensure that the water quality of the spindle chiller is clean.
    Pay attention to the following points at ordinary times:
    1. The water quality must be clean and free of impurities to prevent blocking the water inlet of the motor;
    2. The water pump power cannot be too small, otherwise the water circulation cannot be well performed due to the height difference between the spindle and the water pump;
    3. Pay attention to frequently replacing or adding pure water to avoid too long water circulation time, too high water temperature, and scale in the spindle water circulation pipeline;
    If your problem is still not solved, you can contact us at any time:
    https://www.elephant-cnc.com/
    https://www.cncrouter-shop.com/
    Email: [email protected]
    Whatsapp/mobile: +86-15064026772
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. Water flow sensor
    By Mcbride19 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-03-2019, 04:34 PM
  2. CW-5200 water chiller flow alarm but flow is fine
    By dogeatdog5 in forum For Sale Only
    Last Post: 03-12-2018, 11:32 PM
  3. Just bought a Flow Water Jet
    By wileybrett in forum Waterjet General Topics
    Last Post: 01-16-2017, 08:55 PM
  4. Recommended water flow.
    By Go-C in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-23-2015, 06:05 PM
  5. Water won't flow
    By Pysiek in forum Spindles / VFD
    Last Post: 05-30-2015, 04:16 PM
