603,794 active members*
3,282 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > screwless vice clamp blocks
Results 1 to 9 of 9
    Jun 2003
    1365
    Hi, I bought a screwless vice and am working on some clamping blocks, I took some measurements on the vice and compared them to the blueprints LMS has on their site, is there any specific reason they are where they put them? they say .62" and I have .691" from bottom to center.
    Im curious how I should design these, where i should put the drill rod in perspective to the hole.
    If someone has any information for me, please let me know, I want to make these tomorow, I have everything but those holes done, I need to get my other vice in the mail.
    Thanx
    Jon
    234
    JFettig,
    If you are talking about the 3" screwless vice from LMS. Just build them like the drawing and they will work great. Just finished some myself two weeks ago.
    Marv
    Jun 2003
    1365
    alright thanx. from what I saw, it looks like they wont really be touching the table of the mill much?
    Jon
    Jun 2003
    8
    Can you give me the Web address for LMS ! please?
    thanks
    Regards
    Rich Monforton
    Jun 2003
    1365
    littlemachineshop.com
    I made these blocks and they dont even touch the table. I can see they will hold down the vice, but they probably could be touching the table dont ya think?
    Jon
    234
    Actually the end that is away from the vice should touch the table for proper clamping of the vice to the table. There is a shoulder on that end that is suppose to touch. The rest does not.
    Marv
    Jun 2003
    1365
    that is what I thought too, thats why I started this thread asking about it.
    You say yours touch and you build them like the drawing?
    Jon
    234
    Yes, the end with the shoulder touches. If you have a different vice, you may have to relocate (either raise or lower) the holes for the pins so that the opposite end of the block touches the table. You will get much better clamping if the end of the block with the shoulder rests on the table. If it doesn't, you will not get much clamping force and the vice could move under heavy cutting loads.
    Marv
    Jun 2003
    1365
    It sounds like I need to make new ones, I sure hope I can make new ones with this vice as is, maybe Ill put something under that end for the time being.
    Jon
  1. iko blocks seem too stiff.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 03-14-2005, 08:50 PM
  2. Dirction / Step lines!
    By bigal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2005, 08:51 PM
  3. Advant./disadvant. Of Milling Vice
    By FLUTE HEAD in forum MetalWork Discussion
    Last Post: 09-27-2004, 05:35 PM
  4. My First CNC tool: Mangle (or vice) with picture
    By gcamlibel in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 07:14 PM
  5. Making your own pillow blocks and Rail mounts?
    By Zephrant in forum DIY CNC Router Table Machines
    Last Post: 05-20-2003, 12:34 AM
