603,373 active members*
3,938 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Have you ever used one of these?
View Poll Results: Do you own or have you ever used a Planer Gage in a machine shop or tool room?
Voters
127. You may not vote on this poll
  • Yes, I own one and use it occasionally.
    53 41.73%
  • Yes I have, but don't own one!
    19 14.96%
  • I have seen them, but don't know how to use one!
    20 15.75%
  • What the heck is it for any way?
    35 27.56%
Page 1 of 2 12
Results 1 to 20 of 32
    This is a Planer Gage!
    This mysterious tool is very old and nearly obsolete! A planar gage is hardened and precision ground with a t-slot on the center of the angular surface. The t-slot is used to clamp the slide securely while a dimension is either set with a micrometer or height gage, or transferred from an application such as cutter height, to a surface plate to be read by a height gage.
    Many people use them a solid base for an indicator, such as a surface gage. I believe the original usage was setting the cutting tool height or depth on older milling machines.
    Widgit
    Mar 2006
    2712
    As the name implies, it's original purpose was to set the tool heght on a planer. Only us antiques seem to know what that is/was. The planer was the predecessor of the planer mill now known as a bridge mill. They date back to the days where a shaper was in common use. The planer gauge works great for supporting flat work for surface grinding etc. Treat it kindly, it's a precision piece.
    DZASTR
    i may be wrong but i beleave they were most popular on shapers
    would be a nice adjustable parallel or adjustable work stop
    May 2005
    2502
    I noticed your use of one on the turret project and promptly added it to my todo list. It looks very handy for situations where I should not be using a calipers! LOL
    Best,
    BW
    Feb 2007
    162
    I use one very often.
    I've found it's perfect for setting the Z zero on a 3 axis milling machine when the part is a odd shape or there's no suitable surface to work from.
    I use a .005 or .010 plastic shim to touch off with the tool. Never fails me.
    ...and no batteries.
    enat
    ...oh and the name comes from the machine it is used on, a planer, it looks like a big shaper. And it is widely used on a shaper too. ...for setting the tool height.
    Mar 2007
    463
    Here is what a planer looked like when that tool was designed. http://www.maneklalexports.com/Photo...ols/Planer.jpg
    It is similar to a shaper, except the table traveled back and forth and the tool only moved side to side, across the part. These were used for large parts, some of the tables measured over 40 feet long. Shapers were used for smaller parts, generally less that two feet long, and the tool moved on a ram in and out. The part moved side to side.
    The planer gage was used to set the starting height from the table or from a stack of height blocks. It also allowed you to look at the angle of attack on your tool, and check the clapper to make sure that on the return pass your tool was not dragging on the cutting edge.
    Jun 2004
    12
    planar gage for setting tools
    I use it to set the Z height of my tools so I do not have to change the Z offset. when I change routing bits I can set them at the same height by setting the planar gage on the table & adjust it until it hits the bottom of the bit to be replaced. A a shim preserves the gage surface. I then remove the worn tool, load the new tool, adjust the length of the replacement tool until it touches the planar gage step that was set and tighten the bit. my router does not have a positive way to set Z height when importing a CNC file so I use it alot. please note it is a "gage" and is used as an adjustable gage block when zeroing a dial indicator to a specified blueprint height. it is old technology that is still useful.
    Apr 2006
    3206
    A planer gage is one handy tool. On a surface plate for layout or inspection, on a mill, for holdin' one end of somethin' up while you do something to the other end...
    Its like a big adjustable parallel!
    Jul 2005
    12177
    Here is a really tiny planer.
    Dec 2004
    524
    Quote Originally Posted by fizzissist View Post
    I disagree. Twice. Yes, it is handy for layout or inspection. It is a precision tool that is NOT to be used for holding something up. The same is true of adjustable parallels. They are intended to be used to transfer measurements; not to hold things up. Vises and jacks are used to hold things up.
    The same logic leads me to believe that micrometers are not to be used as C clamps -- although they have a similar shape. :-)
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Jul 2005
    12177
    Quote Originally Posted by lerman View Post
    ....The same logic leads me to believe that micrometers are not to be used as C clamps -- although they have a similar shape. :-)
    Ken
    Oh, I don't know...the fine thread means they clamp reeal tight .
    Dec 2006
    247
    Does that mean I can use my crescent wrench to measure parts with.
    Jul 2005
    12177
    Quote Originally Posted by joecnc1234 View Post
    No! that tool is for driving nails.
    Mar 2007
    67
    Function of Planer Gages
    Very informative page, scroll down for "Planer Gage"
    http://www.wisc-online.com/objects/MTL3902/MLT3902.htm
    Nov 2006
    154
    Geof....what is the best way to use calipers to wring that last bit of tooth paste out of the tube?
    Steve
    Dec 2005
    93
    Can't use micrometers as clamps??? Who would have guessed that one.... Dang, ya learn somthing new every day.....
    Gotta go by some clamps to replace my micrometers......
    I agree that the planer gage is a PRECISION tool, for transferring measurments and used in conjunction with surface plates and test indicators.
    Aug 2007
    Shut height of a die
    I used a planer gage to measure shut heights of large dies to build the solid stops. Also used them for adjustable stops on smaller form dies to check clearances.
    Mar 2008
    240
    Tool & Die Makers use planer gages all the time. Also used in inspection. Today mostly replaced by Cadillac gages.
Page 1 of 2 12
