587,567 active members*
3,716 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > adding inertia dampeners on nema34
    Apr 2018
    20
    hi everyone,
    i have a plasma table with nema34 motors on it.
    these have at certain speed vibrations.
    i would like to add some inertia dampener to help that.
    here's where i got the idea from:
    https://www.cnczone.com/forums/stepp...er-damper.html
    issue is that my stepper motors only have 1 shaft.
    the back of the motor has a round detent of 30mm in diameter and about 3mm deep.
    at the bottom of this detent there is a thin plate (i can see it move when i push on it).
    here's a picture:
    https://www.cnczone.com/forums/attac...d=412332&stc=1
    does anybody know if it's possible to attach a dampener to this motor
    this is what i wanna add to the motor:
    https://www.cnczone.com/forums/attac...d=412334&stc=1
    does anyone know what there is behind the thin plate?
    could i attach the dampener to whatever there is?
    thank you
    Jun 2015
    943
    Re: adding inertia dampeners on nema34
    Why not trying a stepper drive with mid-band resonance damping? I mean that is also a solution for your problem.
    I think the dampener will only shift the resonance band, it will not likely to fully resolve the issue.
    Apr 2018
    20
    Quote Originally Posted by OlfCNC View Post
    i bought the table from a company who made the machine, but they are no longer in buissines.
    i don't have the know how to install new drivers.
    on the thread i linkend to alot of people have really great result, seems like it's worth a try.
    Jun 2011
    692
    There may be a preload spring or something in there. Modifying the motor seems quite risky to me. I think I'd replace the motors with equivalent dual shaft motors, or upgrade the drives. There may be drop-in replacements for the drives available, stepper drives are fairly interchangeable.
  1. Steppers stalling/missing steps - yoocnc 6040z 80s. DAMPENERS?
    By Craig - Pacific in forum Stepper Motors / Drives
    Last Post: 09-23-2013, 08:14 PM
  2. Inertia probem
    By furyomen in forum Mechanical Calculations/Engineering Design
    Last Post: 07-30-2013, 10:25 PM
  3. low or medium inertia for router?
    By Boltz in forum Servo Motors / Drives
    Last Post: 03-25-2011, 11:41 AM
  4. Vibrational Dampeners for Mill Bed
    By Vogavt in forum Benchtop Machines
    Last Post: 01-22-2011, 09:12 PM
  5. Help, Inertia or Torque
    By gdb in forum Stepper Motors / Drives
    Last Post: 04-30-2007, 09:30 PM
