587,354 active members*
3,155 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > User Graphic Command
Results 1 to 3 of 3
    Aug 2011
    421
    Hi
    How can we use any variable in the definition block of UGC?
    sample
    LEN1=any number
    DEF WORK
    PS LC,[0,0],[LEN1,50]
    END
    "Imagination is more important than knowledge."
    Jun 2015
    4156
    Re: User Graphic Command
    hi, i also tried, and it failed ... but, what about creating a macro, so to handle this ?
    code will be like this :
    Code:
    [ main-program.min ]
    CALL ODRAW
    // program continues
    M02
    [ odraw.ssb ]
    ODRAW
    (------<DRAWING DATA>------)
    NOEX VTLIN[4]=3 VTLFN[4]=1 VTLL[4]=50 VTLA2[4]=3 VTLA1[4]=80
    NOEX VTLIN[6]=8 VTLFN[6]=1 VTLD[6]=12 VTLL[6]=50 VTLA2[6]=5 VTLA1[6]=80
    NOEX VWKR=9999.999 VCHKL=0 VCHKD=0 VCHKX=80 VCHKZ=-38
    DEF WORK
    PT LF,LC,[-38,0],[80,80], [38,0]
    END
    DEF WORKF
    PF 0,[0,0],80,D
    END
    CLEAR
    DRAW
    RTS
    is possible to parameterize entire odraw, by creating a soubroutine that will generate linear code (g-code), starting with some numbers
    so you use LEN1 inside main program, generate the soubroutine, and the main program will call it; downside is that it will require to create the soubroutine before executing the main program, thus more keystrokes; if u wish, i will create an example
    to do it without auxialary keystrokes, then it will be required to create the code like you wish, before sending it to the machine, and i can't do that / kindly
    Jun 2015
    4156
    i mean a parametric, like this :
    Code:
    [ test.min ]
        NOEX LEN1 = 60
        FWRITC odraw.ssb;C ( append c = rewrite existing content )
        NOEX PUT 'ODRAW'    PUT $0D0A
    $        PUT 'DEF WORK' PUT $0D0A
    $        PUT 'PS LC,[0,0],[' PUT LEN1 , 3 PUT ',50]' PUT $0D0A
    $        PUT 'END'      PUT $0D0A PUT 'RTS'
        WRITE C
      ( CLOSE C )
    M02
    that generates linear code :
    Code:
    [ odraw.ssb ]
    ODRAW
    DEF WORK
    PS LC,[0,0],[ 60,50]
    END
    RTS
  1. Graphic
    By trevor2306 in forum Colchester Tornado lathes
    Last Post: 07-23-2015, 08:39 PM
  2. Move command works until velocity command issued
    By madprinter in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-30-2015, 01:06 AM
  3. Replies: 2
    Last Post: 06-11-2013, 11:26 PM
  4. VCarve Pro user needs Aspire user help
    By ntww in forum Vectric
    Last Post: 10-08-2009, 03:08 AM
  5. Graphic
    By Marco2407 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-10-2008, 11:00 AM
