Originally Posted by
JTMRMC14
I'm probably missing something very simple but I have been unable to figure out what it is. Any help would be appreciated.
Thanks, Tim
As a few have pointed out, you have the E-stop circuit connected to two separate switch contacts, one N.O. one N.C. these are never common to each other, hence the E-stop circuit will never be closed, on the opposite side of the block to the N.C. there should be another N.C. terminal, these are the two to use.
Al.
Albert E.
