587,523 active members*
3,753 visitors online*
    Hitachi HT20 Alarms
    Looking for a starting point with a Hitachi HT20. At start up I'm getting alarms.
    392 Z-axis Disconnect
    390 Servo Pack Alarm
    310 Power for servo not supplied
    It will allow me to hit the standby button but about 2 seconds later it kicks out and then nothing works.
    Any help would be appreciated.
    Re: Hitachi HT20 Alarms
    The problem seems from Z axis driver, check its cables, connectors, or the driver might be broken.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Thankyou for the response I will start with getting those checked out.
    Jan 2013
    474
    Quote Originally Posted by JSMachining View Post
    After doing the checks recommended by the previous poster, power down machine, lock it off and remove the drive. Take it to your nearest specialist drive repair center (Fanuc?).
    If it were X or Y axis you could swap them to see if the fault moved with the drive.
    Z axis is usually a bigger more powerful drive and on a vertical machine often has a brake circuit. (Probably not in your case).
    I suspect drive transistor fault or power supply.
  1. Hitachi Seiki HT20
    By Gerichchokes in forum Hitachi Seikis
    Last Post: 08-17-2021, 09:58 PM
  2. Hitachi Seiki HT20 has alarm
    By HTPMachine in forum CNC Machine Related Electronics
    Last Post: 04-11-2019, 03:48 PM
  3. Hitachi Seiki HT20 Documentation
    By Dave. in forum Mori Seiki lathes
    Last Post: 11-18-2018, 06:50 PM
  4. Hitachi-Seiki HT20 S2 Need some operating Help Please.....
    By blakemachine in forum Mori Seiki lathes
    Last Post: 11-02-2012, 03:03 AM
  5. hitachi seiki ht20 fanuc T3
    By zeeshaniqbal in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-13-2009, 08:42 PM
