Hi guys,
I'm trying to overcome an issue of the gantry yawing caused buy the gantry being too wide for the centerally mounted leadscrew. I think the easiest way I could overcome this is by running a cable system in a figure 8 layout with pulleys inside each corner below the table and the cables secured to the cross member which runs under the table (what the leadscrew nut is mounted to).
I've only had a quick look on the net to try and find a supplier of wire rope who sells by the meter but all I have found so far is supplier who sell by the roll (hundreds of meters). I really only need about 7 meters of rope and the diameter shouldn't need to be any more than about 3mm.
Anyone know where I might get this? I'm in Geelong by the way.
Cheers
Splint
