587,603 active members*
4,047 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > AC Servo motors, are they all three phase?
Results 1 to 6 of 6
    Jan 2021
    I have been looking at getting a couple of servo motors for a system I am putting together. I am interested in 1000W version of this series of AC servo drive.
    https://www.damencnc.com/userdata/fi...glish_2018.pdf
    To me the manual is a little ambiguous on the required power. It has single phase AC for control, and three phase for motor drive. However the way it is written makes me think that it might be optional and not required?
    If I am wrong here, am I fundamentally looking for something impossible, AC servo on single phase power?
    35538
    Re: AC Servo motors, are they all three phase?
    See page 3-4.
    You can run models 1.5Kw and less on single phase.
    Dec 2003
    24220
    Quote Originally Posted by csreades View Post
    Most AC, BLDC, ECM motors are fed from power of 1ph origin, but as Gerry pointed out, to obtain a smoother, more efficient DC power supply when running the larger versions of motors, 3ph is required or optional.
    IOW, The 3ph or BLDC servo power is derived from a DC supply.
    Al.
    Albert E.
    Dec 2003
    24220
    Incidentally the BLDC motor is constructed identically to the 3ph version, just the means of commutation and operation is different, the BLDC has only 2 winding's connected at any one time, as opposed to the 3ph three winding connection.
    Each can be turned into the other quite easily.
    Al.
    Albert E.
    Jan 2021
    Thank you both for the really helpful replies. And apologies it seems I did not read the manual very well!
    For motor equal or less than 1 KW, some brands can make both single phase or three phase, it is optional.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Replies: 34
    Last Post: 08-17-2021, 07:16 AM
  2. connection of three phase motors to VFD
    By kunte in forum Spindles / VFD
    Last Post: 03-18-2018, 10:14 PM
  3. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  4. Three Phase Motors
    By Halfnutz in forum Stepper Motors / Drives
    Last Post: 09-23-2006, 03:35 AM
  5. 2 phase vs 4 phase stepper motors
    By Don C in forum CNC Machine Related Electronics
    Last Post: 05-26-2004, 07:40 PM
