hello, please, can i verify something like this :
1) 2 boolean expressions
v1=11
v2=22
IF [ [ v1 EQ 11 ] EQ 1 ] AND [ [ v2 EQ 22 ] EQ 1 ] ...
2) text
VUACM[1]='some_text'
IF [ VUACM EQ 'some_text' ]
kindly !
v1=11
v2=22
2) text
kindly !
hello guys & girlsi am updating an old code, and i wish to share this :
code is shorter & executes fasterCode:IF [ condition ] N1 ( old stuff ) GOTO N2 N1 // true branch GOTO N3 N2 // false branch ( GOTO N3 ) N3 ( . . . . . . . . . . . . . . . . . . . . . . . . . . ) IF [ condition ] NTRUE ( new stuff ) ( NFALSE ) // false branch GOTO NDONE NTRUE // true branch NDONE NOEXkindly !
hy past self of me
still have no clue / it may not be possible, but is not a mustCode:do this : IF [ [ [ V1 EQ 11 ] AND [ V2 EQ 22 ] ] EQ 1 ] NTRUE * you forgot to use common factor : " EQ 1 " checking multiple conditions is also possible : IF [ [ [ condition_1 ] AND [ condition_2 ] AND [ condition_3 ] ... AND [ condition_n ] ] EQ 1 ] NTRUE * the only restriction, is that the entire text must be contained within 1 line of code![]()
hellocode is shorter & executes fasterCode:IF [ condition ] NTRUE ( new stuff ) ( NFALSE ) // false branch GOTO NDONE NTRUE // true branch NDONE NOEX
bellow are even faster execution codes, and there is room for more; the gain in speed between variants of previous post from 2018, and the one from today, is much more smaller, much more subtle, thus this post should have no relevancy for average codes, but only for situations where computation times really matters, like heavy loaded math driven codes, that affect execution time
if you feel like you need speed, then, to boost up code, get rid of comments, spaces, shorten the N*** sequence names, join blocks&codes, and in the end, nothing beats linear simple code ... unless, there is situation where linear code will not perform better than a macro, and this is a class of specific cutting operations
in short, to get speed, is needed to reduce the space that the code requires, making it much more dense, and writing it in a way that scenarios that usually execute will not pass through condition of those cases that execute with less frequency; as more and more conditions are used, the code becomes harder to follow, and for such situations i use a simple to read code, on which i apply formatting functions to make it denser, thus all debuging does not occur on the code in it's final shape / kindly
Code:IF [ condition ] NT ( false ) // false branch GOTO ND NT // true branch ND NOEX ( . . . . . . . . . . . . . . . . . . ) IF[condition]NT // false branch GOTO ND NT // true branch ND // replace NOEX with next block
