587,143 active members*
5,437 visitors online*
Results 1 to 5 of 5
    Oct 2006
    5
    Letter engraving
    I have a several plaques to engrave, the gcode was created with MasterCam, it works fine when I run it on a Haas mill. I needed to have a faster spindle speed and feed rate, the college purchased a cnc router with mach3.
    when I run the same program many of the letters and numbers do not come to a complete close ( small gaps ) as if the spindle is lifting out of the letter/number to soon or entering to late.
    Any suggestion would be greatly appreciated. this is a community project I have been asked to work on.
    Dec 2013
    5714
    Re: Letter engraving
    Are you using the Mach3 post for MasterCam? The Haas post may not be compatible with Mach3. It could also be an issue with ramping in and out of the cuts.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2006
    5
    I am not using the Mach3 post, I was looking for it. I have tried changing some settings in Mastercam thinking as you that its a ramping / lead in/out issue.
    Link for Mach3 post?
    Dec 2013
    5714
    Maybe try here https://www.machsupport.com/download...st-processors/
    Disclaimer: I have very limited experience with both MasterCam and Mach3, so I can't help with anything but some general observations.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2006
    5
    It appears to be a deceleration issue, I added a G8 to turn on deceleration and got the gap to close up. this unfortunately increased run time by more than 50%. I will now see what I can do to adjust deceleration and increase run time.
    Thanks for you suggestions.
  1. engraving each letter individually
    By Jmod60 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-13-2018, 11:36 PM
  2. Need Help with engraving letter stamp
    By WOTDesigns in forum Mastercam
    Last Post: 09-15-2015, 11:41 PM
  3. Engraving letter in aluminium
    By pretorian77777 in forum ArtCam Pro
    Last Post: 02-26-2014, 02:54 PM
  4. engraving letter a problem
    By MIDDEN300 in forum BobCad-Cam
    Last Post: 08-11-2012, 05:25 PM
  5. Letter-engraving tool
    By Vard in forum Wood Lathes / Mills
    Last Post: 03-29-2012, 11:53 PM
