587,229 active members*
5,421 visitors online*
Results 1 to 9 of 9
    May 2022
    5
    Spindle will not increase RPM
    Hello everyone. I need some help. My spindle will not come up to speed. It turns on but will not increase rpm’s. Using Mach 4 software. On the screen it shows the RPM change. But the spindle speed doesn’t change. It worked fine 4 days ago. If you would please let me know your thoughts on this. Thank you
    15362
    Re: Spindle will not increase RPM
    Quote Originally Posted by Awk121 View Post
    Check the 0-10v output from the Breakout Board to the VFD Drive is working if it is, then there will be some Parameters to change in the Drive
    Mactec54
    May 2022
    5
    Thank you. I’ll get into the box and check.
    May 2022
    5
    This is what I found. From what I can figure out the red and black wire are my single 0-10v wires. With the spindle running I’m getting .18 volts. If I adjust the RPM on mach4. I’m still getting the same reading. I have a older machine break board is a CRP550. I have a attached few pictures. Thank you for the help
    15362
    Did this work before or is this a new configuration ??
    If there is no output at the board level, it is either a software configuration problem or the Breakout Board
    Mactec54
    May 2022
    5
    Yes the machine was working fine last week. Havnt made any changes to it.
    15362
    So it looks like the Board PWM to 0-10v Analog output must of failed see if you can run the spindle from the VFD Drive KeyPad you will have to change a Parameter to do this so the Drive is in KeyPad control and not remote control, what VFD Drive do you have
    Mactec54
    May 2022
    5
    Its a Delta VFD EL
    15362
    Its a Delta VFD EL
    To use the KeyPad to control the VFD you will need to change these (2) Parameters
    02.00=0 (1 For Remote Control)
    02.01=0 (1 For Remote Control)
    Just check these (3) Parameters are set at your maximum and minimum Spindle Hz Rating
    02.11=400
    02.12=400
    01.05=100
    Mactec54
  1. How to Increase RPM on PM-25MV (or similar G0704)
    By CNCJoseph in forum Benchtop Machines
    Last Post: 05-01-2019, 06:09 PM
  2. SX3 RPM Increase
    By zarthcode in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2011, 09:38 PM
  3. For wood in a mill do I bolt a router to side or increase spindle rpm?
    By slashmaster in forum MetalWork Discussion
    Last Post: 05-12-2009, 06:41 PM
  4. rpm increase ?
    By joe aiello in forum CNC Machine Related Electronics
    Last Post: 04-03-2007, 09:54 AM
