587,997 active members*
1,819 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > surface repair problem
    Mar 2009
    291
    for the life of me i cant seem to repair the missing surface on this modal any help would be great
    thank you
    Attached Files Attached Files
    Apr 2016
    102
    Re: surface repair problem
    Do you mean this surface?
    Barrie @ Composite Specialities Ltd. using BobCAD V29 Mill 3 axis Pro, Geomagic Design, Bricscad V16 and MOI V3
    Mar 2009
    291
    yes sir.
    Apr 2016
    102
    OK, that surface was created from wires that you had already placed in the model.
    It is a 4 sided patch using the two long horizontal lines including the big radius and then the two vertical lines.
    Does that help?
    B.
  1. Blanchard surface grinder repair
    By BJP in forum MetalWork Discussion
    Last Post: 01-16-2013, 05:45 AM
  2. Surface over a surface problem
    By omnitech in forum FeatureCAM CAD/CAM
    Last Post: 10-20-2011, 03:42 PM
  3. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  4. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
  5. ?! Please help me with this surface problem.
    By Ben J in forum Solidworks
    Last Post: 09-29-2007, 06:25 PM
