603,963 active members*
1,908 visitors online*
Results 1 to 3 of 3
    Sep 2006
    21
    heidenhain tnc 2500 controller
    on my series 11 interact 11 when I try to reference the axises I get a drive axis fault. my voltage coming out of transformer T-2 is 185 off of the 2 180 legs & 385 coming off of the 380 leg. can somebody help me with this problem? If I go into manual mode the spindle will operate but none of the axis will operate.
    Nov 2004
    3028
    It sounds like you have a bad BOSCH axis drive board which the control is seeing.
    George
    Sep 2006
    21
    George how do I tell which board is bad? All three are showing the same l.e.d's lit up and when I isolate them individually I get the same response.
  1. Heidenhain 2500 parameters
    By Daninwyoming in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2018, 07:38 PM
  2. Heidenhain tnc 2500 on Interact 308
    By GarageShop in forum Bridgeport / Hardinge Mills
    Last Post: 12-15-2010, 11:57 PM
  3. Heidenhain TNC 2500 in Interact 308
    Last Post: 08-24-2008, 10:16 PM
  4. Heidenhain 2500 question
    By greg b in forum Bridgeport / Hardinge Mills
    Last Post: 10-29-2007, 09:39 AM
  5. Heidenhain 2500
    By nycooh in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-17-2007, 08:57 AM
