587,302 active members*
3,329 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Upgrading my CNC DIY Lathe just need a couple of answers please.
Results 1 to 5 of 5
    Jun 2013
    443
    Small Chinese lathe with a 900mm bed and a 240mm throw. It was originally a manual machine I converted to a CNC lathe. I dont use it much but when I do its awesome to a point. I have a few problems I am addressing now and was hoping an experienced turner can pop some opinion into this post.
    Wanting to control my motor electronically I installed a 2hp treadmill motor that didn't have enough torque. I am installing a different 1.5kw 3 phase motor with a VFD, it will have a huge amount of torque in comparison. But I am not sure what speed range to work on when I sort out pulleys. What would I want to look for at the chuck? 500-2000rpm? Or?
    Too much backlash using the standard acme hand screws I am installing some ballnuts on ball screws to remove all backlash. I am going to leave the main carrier but for the Z axis, would I be better to take the gibbed plate off and replace it with good linear rails on the saddle to hold my tool holder and eventually a turret? Once I remove the backlash on this axis it needs to be reasonably tight to be satisfactory. If I put linear rails on I will be able to move that axis a lot quicker. But is it worth doing?
    oh. Just two questions really. Thanks
    Re: Upgrading my CNC DIY Lathe just need a couple of answers please.
    It is a small lathe machine.
    Buying a new CNC lathe machine could be more cost-effective.
    And less trouble.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jun 2013
    443
    Quote Originally Posted by cncmakers001 View Post
    And less trouble.
    Dear cncmakers001. Might be for you my friend. You assume incorrectly. Perhaps if I was beginning right from the start, but this is an upgrade. If you have some good educated robust advice for me and this forum I offer a clean slate for your keyboard.
    Oct 2013
    543
    My two cents...for a small lathe like that, you'll probably be using higher R PM's more than slow ones, but having said that, I think a sheave ratio to achieve the speed you've listed would be good. You can pick a middle of the road HZ (+) on your drive to get you those desired speed parameters, then be able to drop some RPM as well as over-speed the drive for anything higher...they can easily tolerate 120 Hz.
    Regarding your cross slide/compound changes using linear rails, if you have room for that modification, I think it's a great upgrade.
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
    Jun 2013
    443
    Quote Originally Posted by atomarc View Post
    Stuart
    Thanks. Worth more than 2 cents too. Great. Ok. I am into it. We think, we begin. I have installed the motor with a new adaptor plate. It didn't take long to rebuild the Z axis I bored out the saddle and inserted a 2005ballnut, threaded a 2005 screw I have and thats all good too. Just waiting on a keypad for the second hand VFD I bought, I cant seem to connect to it with my PC to program it.
    The final upgrade is the X axis. It will be very easy to pop a couple of HG rails on the saddle and manufacture a new top to accept my post. I was actually thinking about making a turret - I need to research more. Like, is Mach 3 capable of toolchanges and the length offsets I would need is a question I need to find out. I was considering using a quickchange toolpost for a manual type of toolchange.
    I guess I will get this done. And go back to using my cnc lathe once in 3 months. Or, I may find I use it all the time and am lost without it. Either way, its a cool project.
  1. Cnc Code questions and answers cnc lathe platform
    By zzakamo in forum DIY CNC Router Table Machines
    Last Post: 01-30-2021, 01:31 PM
  2. Query regarding upgrading a Sieg C6 lathe to CNC
    By -= Keith =- in forum Syil Products
    Last Post: 12-23-2011, 12:31 PM
  3. Ok, I need some straight answers about DIY milling machine!
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 11-27-2006, 05:00 PM
  4. Ok, I need some straight answers about DIY milling machine!
    By chola in forum DIY CNC Router Table Machines
    Last Post: 11-27-2006, 04:10 PM
