603,800 active members*
3,834 visitors online*
IndustryArena Forum > CAM Software > UG NX > Issue with Parametric Part Configuration: Excel-linked Fastener Sizes Not Updating
Results 1 to 1 of 1
    Aug 2023
    Hello NX Users,
    I'm a fellow NX user who's been dealing with an issue related to parametric part configuration. I've been trying to pull parameters from an Excel file for my part model, and I've noticed that these parameters aren't updating correctly.
    Specifically, I'm attempting to add fasteners of different sizes based on diameter measurements. I have the necessary data and connections within my Excel file, but I'm struggling with how to incorporate these data parametrically within my part file.
    I've double-checked the Excel file's location and connections, and I'm confident everything is set up correctly there. However, I'm having trouble understanding how to configure the parameters and features within my part file.
    If anyone has experience with such parametric configurations or could provide any insights on this matter, I'm looking for someone who can guide me on which steps to follow or what configurations to adjust properly.
    Any information or experience sharing on navigating such parametric setups would be greatly appreciated.
    for example MW Standard Part Library, meusburger, Guide Lock, E2680
    Thank you.
    Best regards,
    Murat GÜMÜŞ
    Jun 2015
    4190
    Re: Issue with Parametric Part Configuration: Excel-linked Fastener Sizes Not Updatin
    hy i don't use nx, but i can help create parametric programs from excel.
    Jun 2015
    4190
    another thing just crossed my mind minutes ago : take your nx file with the part, and save it then change each dimension, that you wish to parameterize, with 0.123, or something, thus make it different, and save again
    then share the 2 files, and the list of dimension for each; from there, i may be able to deliver all variants, as nx files / kindly
    Jun 2015
    4190
    i tried yesterday to dig a solidworks file, and a simple change triggered a cascade of changes ... but this may not be true with an nx file
    another aproach is to generate dxf's files from excel, then use them as input for the nx; if there are many such files, thus manually selecting each one leads to too much time waste, then it may be possible to automatize implementation
    please, feel free to ask anything
