603,861 active members*
4,541 visitors online*
Results 1 to 2 of 2
elmerbug Langmuir Crossfire DIY THC -... 03-14-2024, 03:58 PM
campet Re: Langmuir Crossfire DIY... 05-25-2024, 01:32 AM
    Jun 2021
    Langmuir Crossfire DIY THC - questions
    Guys, I'm fairly new to CNC plasma. I am doing a somewhat ambitious project and realized right away that a cnc plasma table without THC is very limited. I will be adding THC to my table, but have a few questions. Your wise thoughts would be much appreciated.
    1. There is so much information out there on this topic that it's difficult for a newbie to sift through and get the real scoop.
    2. With the Crossfire, I believe I will need a Z-axis such as the Rattmmotor CBX1605 (https://www.amazon.com/Actuator-CBX1...22&sr=1-3&th=1), a floating head slide such as the KARVECUT-25 MM CNC FLOATING PLASMA TORCH HEAD (https://step-motion.com/products/25-...mount-assembly), 2 limit switches for the Z-axis limits, and a THC controller kit. Is this list complete?
    3. Which DIY THC controller kit makes sense for my application? Where does the term "standalone" come into play?
    4. Langmuir wants $750 for this add-on. It seems like I can DIY this for maybe $300 and learn at the same time. Yes, no, crazy?
    Thanks in advance, guys.
    Feb 2007
    26
    Re: Langmuir Crossfire DIY THC - questions
    With KARVECUT-25 MM CNC FLOATING PLASMA TORCH HEAD (KARVECUT-25 MM CNC FLOATING PLASMA TORCH HEAD) you are ready to go.
    You can find settings online,on how to set it up with Mach3.
    You can also purchase the Z axis specifically design for small plasma tables,like Langsmuir.
    (https://www.ebay.com/itm/114942262002?).It has floating heat attached to it.
    Those guys they can make mounting back plates (free) to fit on your gantry.
    https://www.youtube.com/shorts/L8EOc3k5R9c
  1. Has anyone used a Langmuir crossfire
    By Jordan3991 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-29-2020, 05:21 PM
  2. Home made rotary 4th axis on a crossfire cnc plasma questions
    By Jgorm in forum CNC "do-it-yourself"
    Last Post: 12-05-2019, 04:18 AM
  3. PowerMax30 THC - DIY with MACH3
    By asi777 in forum Hypertherm Plasma
    Last Post: 11-30-2016, 05:24 PM
  4. need help on diy thc for my plasma table
    By carl benz in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-11-2013, 04:52 AM
