603,834 active members*
2,777 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Blue Elephant CNC > Blue Elephant Hot Products > Top Ranked 5?1 CNC Bridge Saw Machine with Italy*ESA*System
Results 1 to 1 of 1
    Nov 2011
    489
    1. The A axis can automatically rotate 0-90°, while the C axis can rotate up to 360°.
    2. The slab can be positioned by taking photos. In addition, this machine can automatically plan the cutting path directly from the generated map, greatly improving processing efficiency.
    3. The overturned worktable is adopted, which has large overturning weight redundancy, up to 85°.
    4. The Italian servo motor is used to complete circular cutting, square cutting, fan cutting, oval cutting, 45 bevel cutting, drilling, outer edge polishing, etc.
Name:	5?1 Bridge Saw 02.jpg
ID:	510042Click image for larger version.
Name:	5?1 Bridge Saw Part 1.jpg
ID:	510044Click image for larger version.
Name:	5?1 Bridge Saw Part 2.jpg
ID:	510046Click image for larger version.
Name:	5?1 Bridge Saw Part 3.jpg
    E-mail: manager@elephant-cnc.com Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. China Top Stone Bridge Saw for Sale New Zealand
    By elephantcnc in forum Other Machine Topics
    Last Post: 09-18-2023, 10:16 AM
  2. Replies: 1
    Last Post: 12-02-2009, 04:13 PM
  3. my hotwire cnc machine from Italy :-)
    By romy in forum CNC Wire Foam Cutter Machines
    Last Post: 11-05-2008, 12:32 PM
