603,385 active members*
2,957 visitors online*
    Oct 2018
    11
    RS232 cable for Ajax lathe
    I want to make up a 9-pin to 9-pin cable for downloading to an Ajax CNC lathe. What pin-to-pin connections should I have?
    2--3
    3--2
    5--5
    Oct 2018
    11
    Re: RS232 cable for Ajax lathe
    ..Control is a Fagor 800T
    Feb 2025
    Standard Null Modem (Crossed) RS-232 Pinout:
    Pin 2 -> Pin 3 (TX → RX)
    Pin 3 -> Pin 2 (RX → TX)
    Pin 5 -> Pin 5 (Ground)
    Pin 7 -> Pin 8 (RTS → CTS)
    Pin 8 -> Pin 7 (CTS → RTS)
    Pin 6 -> Pin 4 (DSR → DTR)
    Pin 4 -> Pin 6 (DTR → DSR)
    Pin 1 -> Pin 1 (Carrier Detect → Carrier Detect, optional)
    Pin 9 -> Pin 9 (Ring Indicator → Ring Indicator, optional)
    Simplified (Common) Wiring:
    If your CNC lathe does not use hardware handshaking, then you’re right- the minimum required connections are:
    Pin 2 -> Pin 3
    Pin 3 -> Pin 2
    Pin 5 -> Pin 5
    Oct 2018
    11
    Thanks - I will try it
  1. RS232 CABLE FOR MILLTRONICS C7
    By VBUZZ in forum Milltronics
    Last Post: 09-16-2011, 03:24 PM
  2. rs232 cable
    By Mazaman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-01-2010, 11:28 AM
  3. RS232 cable
    By Zep in forum DNC Problems and Solutions
    Last Post: 09-05-2008, 02:46 PM
  4. rs232 cable
    By Dar in forum Bridgeport / Hardinge Mills
    Last Post: 12-13-2007, 07:51 AM
  5. Fanuc om-d rs232 cable
    By Julian M in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-01-2006, 11:20 PM
