603,784 active members*
17,654 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3 conversion - ballscrew mounting question
Page 1 of 3 123
Results 1 to 20 of 53
    Aug 2005
    131
    I'm buying 3x Roton ballscrews and ballnuts this week for my Grizzly X3. For the conversion, I'm machining all the aluminum pieces myself rather than buying a kit. I'm also bribing a machinist friend to turn the ends down on a lathe and do the threading on the ends.
    My question is, should I secure the ballscrew from both ends, or just a single side like the CNCfusion kit? (see link below)
    http://www.roton.com/application_engineering.aspx#16
    The link above shows four styles of mounting a ballscrew (fixed/free, supported/supported, free/supported, and fixed/fixed). The CNCfusion kit seems to be fixed/free. Would a fixed/supported or fixed/fixed system be overkill?
    Apr 2007
    201
    There have been a few people complaining about roton here. For my conversion I was going to research it further....
    Homeshop cnc used to offer good ballscrews but it looks like they are switching over to another brand????
    Jun 2006
    2512
    How you fix it depends on how fast you intended to run it. Is there some reason to doubt the procedure for determining the mounting layout given in the Roton link you posted.
    Phil
    Quote Originally Posted by Neil_J View Post
    Nov 2005
    655
    I like fixed/supported for X and Z and fixed/free for the Y. If using direct drive on the motor mounting I'd put the motor on the fixed end.
    Walking is highly over-rated
    Aug 2005
    131
    Quote Originally Posted by philbur View Post
    Phil
    I won't be running super-fast rapids or anything. No reason not to use their procedure, I just like to get rules-of-thumb and personal accounts from people before starting an important project.
    Aug 2005
    131
    Quote Originally Posted by DonF View Post
    So I should stay away from Roton?? What exactly were they complaining about.. Accuracy? Overall quality? I did a lot of searching but didn't see anything that bad about them (probably looking in the wrong place).. They are pretty cheap so I guess it doesn't surprise me.
    I don't need a super-accurate machine, but it does need to be usable. If I were to map out any linear error in the screws, and use oversize balls to reduce backlash (hopefuly to ~0.001) .. Maybe even a double-nut on the Z axis.. what kind of accuracy can I expect?
    Aug 2005
    131
    Quote Originally Posted by tauntdesigns View Post
    Seems a great way to go. I'll more than likely be going that route.
    Jun 2005
    866
    Fixed/Supported will be fine for the X axis. I am getting 400IPM on my X3 with a .2" lead, fixed/supported X and Z, and never a problem. My ballscrews are 20mm diameter though.
    Jun 2005
    866
    Oh, what kind of ballscrews are these? I used ground ones on my X3, so the diameter was maybe a micron over 20mm. Instead of trying to turn down these beasts, I simply used a 20mm ID radial bearing and had it lightly press onto the end of the ballscrew. Check eBay for ballscrews with at least one end already turned and journaled.
    Apr 2007
    201
    They were complaining about accuracy. I couldnt find where Roton listed it? So that probably means they arent proud of it either.
    Aug 2005
    131
    Yep, Roton doesn't publish specs on their site.. I guess their targeted niche is linear positioning for factory automation.. think machines that cap bottles or ones that move car bumpers around. 6 thou of backlash wouldn't matter there.
    As far as using them for hobby CNC use, I'm still really interested in them because they're about 1/3 as cheap as the other guys. I've read a few places that the linearity over the entire screw isn't great, but I can map that out in Mach3. What worries me is any irregularity in the ball grooves, especially since I'll be using over-sized balls. I just wish someone knew what the repeatability was...
    Feb 2007
    21
    I've had my X3 for about a year now am I'm about to embark on a conversion myself. My issue is that I don't have alot of time to make the parts myself and getting the missus to part with the cash for the cncfusion kit is like pulling teeth...your own teeth. Is there another outlet for the items needed to make the conversion or are my choices limited to cncfusion or make it yourself? I would prefer to buy the ballscrews premade and make the rest myself. Buying a lathe is definately in the plans, but not for a while so for now I would have to pay someone to turn them down for me. I like the cncfusion delux kit but it's a bit expensive for me right now, and I never think that buying the cheaper kit and upgrading later is a good idea. Wow this is frustrating.
    Now that I think about it maybe if someone out there would like to do some trading of services, I have a small powder coating/ceramic coating shop, I could do some coating for you and you could turn down my ballscrews for me. I'm sure we could come to some sort of agreement. I do work mostly for local Hot Rod shops and my quality is very high. I stock a few colors but would be willing to do the work and provide the powder at cost for a trade. Anyone? Anyone?
    Aug 2005
    131
    Quote Originally Posted by BZER1 View Post
    Yep, the CNCfusion kit is nice, but expensive compared to a 100% DIY conversion. Also be glad you're not converting an RF-45 size machine, those kits run $4500 for the ballscrews/mounts, driver, and power supply. I should be able to convert my X3 for about $400.
    Why not find a machinist to turn the shafts down for you, either locally (you should always know at least a few machinist 'friends', I have 3 that I can ask favors if needed), or go to www.rfqwork.com and pay someone a fair price to turn them. Then make the pillow blocks yourself and buy the hardware (angular contact bearings, timing pulleys/belts, etc) online through McMaster or another similiar store.
    Jun 2006
    2512
    By fitting oversize balls it sounds to me like you are trying to upgrade a tansport quality ball-screw to a precision machine-tool ball-screw. My understanding is that on a transport quality ball screw the backlash may vary over its whole length so adding oversize balls to remove it may end in tears.
    Just something to think about.
    Phil
    Aug 2005
    131
    Phil
    I think you're right
    Maybe I should just go with the Nook ballscrews at 3 times the price. In the long run the price difference won't matter much. What matters is that i have a usable machine when I put everything back together. I need some amount of repeatability in my setup and I won't get that using cheap parts. I've spent a week or so trudging through the web, looking for someone using these screws that is getting decent results, and haven't found much. Some people say they are "good" but don't provide numbers to back it up which leads me to believe that their expectations are pretty low.
    My other option of course would be to use the Roton 'transport quality' ballscrews, Roton double ballnuts and regular size balls.. Then map out the linear error using Mach3. I'd lose some travel but I'd have repeatability. I need to run the numbers and see if I can afford to lose some of my work envelope.
    Jul 2006
    1256
    Roton ballscrews are C10 or T for transport grade,lead accuracy .009.
    McMaster,which I beleive are Nook are C7 at .004/ft
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Aug 2005
    131
    Quote Originally Posted by lgalla View Post
    Larry
    I just got a quote back from Nook, their cheapest line of screws (SRT) are really expensive:
    SEL10408 - 5/8" 0.200" SRT RH double-preload ballnut: $176.26/ea
    SRT9392 - 5/8" 0.200" SRT RH leadscrew (2ft): $27.18/ea
    FLG7570 - flange: $29.42/ea
    WKB10407 - wiper kit: $32.60/ea
    That's waaaay out of my budget. I'd hate to ask what their precision ground pieces go for.
    Jul 2006
    1256
    Neil_J,
    You forgot the angular contact bearings at $327.00 from McMaster.They have a 5/8 nut at $60.00.I am glad I am into wood working and can live with .016.You should read ballscrew basics by Swede in the forum.
    Larry
    Aug 2005
    131
    Neil_J,
    Larry
    Man I hope you're kidding
    Nov 2005
    655
    I got some cheap angular contact bearings from (I think it was) vbx bearings.
Page 1 of 3 123
  1. Ballscrew conversion
    By rodzilla in forum Benchtop Machines
    Last Post: 01-23-2008, 02:40 PM
  2. Enco 8x36 ballscrew conversion
    By James Willis in forum Uncategorised MetalWorking Machines
    Last Post: 08-26-2006, 04:35 AM
  3. Ballscrew mounting
    By m_c in forum Linear and Rotary Motion
    Last Post: 03-11-2006, 10:51 PM
  4. CNC Conversion - Ballscrew Questions
    By Deviant in forum Benchtop Machines
    Last Post: 03-29-2005, 04:35 AM
  5. Mini-Mill Ballscrew conversion?
    By rustyolddo in forum Benchtop Machines
    Last Post: 07-29-2004, 04:22 PM
