I had two high speed CNCs, one 50,000rpm the other 40,000, air driven heads with refirgeration units for the head bearings. Both used Creative Evolution controllers, one was a Defiance VTX the other a Strathclyde HT500. Had to sell them when I closed the business and am intruiged to find out how good these smaller machinesb are by comparison and if I could use them for similar work. We used Delcam Powermill to programme offline, post processed and dumped files that were sometimes 40Mb onto the controllers with masses of points in order to make 30mm x 20mm 3D object very precisely. Seemed vast overkill, the machine had a travel of 1000mm x 400mm. I recall we were needing lookup(?) times less than 4ms and acceleration/deceleration and such to be set up as we sometimes used 0.5mm or 1mm (occcasionally 0.25mm) cutters.
I dont mind if cutting takes longer but I am trying to understand if I could still use Powermill (I know it reasonably well) to programme, I gather the typical controllers drip feed via a parallel port, is it G code and post processed? Does Mach3 send data the same way, not clear how it works. Anyone got their head around these issues that I could chat with?
Mike
