603,853 active members*
3,401 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Fenner Drive out put to motor
Results 1 to 7 of 7
    May 2007
    72
    Have a question about some older DC servo drives.
    I am retrofitting a Lagun that had an Anilam crusader controler on it with baldor dc servos. I have salvaged the motors and power supply and purchased Larkins Viper 200 drives to power the servos.
    One thing I notice is the old fenner drives, used some Coils (like a power supply transformer)(for lack of a better term) in series with the motor output. What is the purpose of the coils? Would they serve any useful purpose in the same place with the viper drives? the reason I am asking is because I also aquired an older servo dynamics drive chasis, and it too has the same coils on the motor output. I plan on using the chasis, being it is pretty clean and some wiring is in place and neat.
    Dec 2003
    24260
    See if this is what you are referring to, from Post #17 on.
    http://www.cnczone.com/forums/showth...t=76055&page=2
    Al.
    Albert E.
    May 2007
    72
    I am assuming you are refering to the armature chokes in the post.
    What exactly does a choke do for a servo motor? reduce current? Reduce voltage? What are the benifits?
    Will I need this on the output of the Viper drive? I think I will also contact larken about this too. What are your thoughts?
    May 2007
    72
    Yes that is exactly what I am refering to ( I see the pic on 17 now)
    Dec 2003
    24260
    I believe the poster in the link was also using Viper driver, see post #42 on the same link for the reason for them, I have always tended to keep them, they have the effect of lessening large current spikes through the motor.
    Being an inductive device, they offer very little or none opposition to DC or current of a slow changing nature, but offer impedance to a very fast changing signal.
    Al.
    Albert E.
    May 2007
    72
    I will leave them just like they are, and use them. It can't hurt. Thanks,
    Apr 2007
    5
    Bobby,
    I am trying to convert a crusader M to a Galil 1830 motion card through a ICM-1900 breakout board. for the servo drives do you know what wires go to witch terminals on the breakout board? I can send pictures and diagrams.
    how can i contact you?
    Paul
  1. Need tech data Fenner/Servo Dynamics SFD1525-12
    By calmissile in forum Servo Motors / Drives
    Last Post: 04-30-2010, 09:33 AM
  2. just installed teh new motor drive, but??
    By johnh in forum Tormach Personal CNC Mill
    Last Post: 02-07-2009, 05:13 AM
  3. Fenner M-Drive
    By pzzamakr1980 in forum CNC Machine Related Electronics
    Last Post: 09-12-2008, 12:03 AM
  4. Replies: 3
    Last Post: 07-04-2008, 12:57 AM
  5. What motor drive for an arm?
    By nervis1 in forum RC Robotics and Autonomous Robots
    Last Post: 12-16-2005, 09:30 PM
