I love printers, they have many uses, one of which is the inspiraton of this build - cheap parts !!!
I acquired a probably working Canon printer today, and got to work making sure it will not work normally ever again
The goals for this build is are follows :
1 - CHEAP ! This is going to be the cheapest but hopefully not the nastiest build log around, I do not apologise for this, rather I am embracing the idea. Parts will either be second hand, or so cheap it won't really matter. I will have some things to aid the build. Hopefully I will have my main DIY router going in a couple of weeks and will use it to fabricate a lot of parts. Also I have built a couple of servo drives, one based on the Elm Chan design, the other the DSPIC servo design, this machine will be a test bed for both.
2 - I need this machine to drill PCB's ONLY ! I will muck around doing some isolation routing once it is finished but this is NOT the design target. I want to be able to load a 300mm by 300mm sheet of copper clad fibreglass, hit the button then let the machine drill out a full panel of circuit boards at a time. Then I will be using either the direct printing method or most probably toner transfer as it will align much easier in larger numbers.
3 - Simple. I hope to provide some basis for the never ending stream of people wanting to do PCB milling. This machine is not designed for this exact purpose but with a little extra work should be able to do so.
4 - Fast. Direct drive timing belts driven with DC motors and linear encoders from printers should do the trick, the motor's may not be from the printer though.
5 - Cheap ! Just in case you missed it
Don't expect any nice pretty CAD renderings of what it is going to look like, this is a "flying by the seat of my pants" type of build.
Next up some photo's...
Russell.
