587,523 active members*
3,991 visitors online*
    Apr 2007
    641
    Help to upgrade old router
    I need some help to upgrade a cnc router. The MAchine is a Biesse - (italian) the ref is ROVER. It has 14 tools . Uses 3 axis servo controlled. Now is working with an old program that uses 3 1/2" disquette, is not easy to work with.
    We want to change it to work with Mach from a PC .
    I have some experience with Step motors (builded 2 4x8 plasma tables.)
    Any help will be fine.0
    Some pics of the machine...
    Luis
    Attached Thumbnails Attached Thumbnails DSC03863.JPG   DSC03853.JPG   DSC03856.JPG   DSC03862.JPG
    Feb 2008
    482
    yours has the 481 controller the same as mine.
    it would be extremely hard to convert to mach etc!
    if its working use it as it is.
    i have a program to write gcode to floppys on a pc which will read direct in 481 controller.
    i also have working postprocessors for alphacam and bobcad. see my other posts for details and what it can do.
    if you do decide to upgrade il buy your old controller from you as a spare!
    Apr 2007
    641
    Battwell, yes I was looking closely and ..yes its a very hard work!!! The machine is fine, Biesse only sell it for panels and boring, but the machine can make a lot of things with all that tools !!!!
    I dont have the electric manuals, can I get it from you?
    And also about the program you use to write the gcode for the floppy , I tried with the sheetcam but it doesn´t work
    Luis
    Nov 2005
    172
    I can send you a document to help with the programming email me at [email protected]
    Hope this helps
    Mark T.
    www.cnccustomservices.com
  1. Where to Get ram upgrade?
    By A+ Machining in forum Fadal
    Last Post: 12-08-2018, 07:38 AM
  2. DIY Upgrade
    By vwpanda in forum DIY CNC Router Table Machines
    Last Post: 02-05-2010, 07:35 PM
  3. I need a low cost upgrade controller for my CNC Router
    By ReefkeeperCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-09-2006, 02:01 AM
  4. Vmc 40 -5 upgrade
    By redman in forum Fadal
    Last Post: 11-19-2005, 02:22 AM
  5. SCM Router controller upgrade help
    By flinty in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-26-2005, 09:20 AM
