Originally Posted by
alwaysready
1 Each 98910A033 Plain Steel Threaded Rod 1/2"-13 Thread, 6' Length $3.99 $3.99
1 Pack 90630A125 Grade 8 Plain Steel Hex Nylon-Insert Locknut 1/2"-13 Screw Size, 3/4" Width, 19/32" Height, Packs of 10 (Same as 90630A888) $4.57 $4.57
1 Each 9721K31 UHMW Polyethylene Precision-Ground Blank 1/2" Thick, 2" X 12" $3.62 $3.62
6 Each 6384K361 Steel Ball Bearing Flanged Double Sealed for 1/2" Shaft Dia, 1-1/8" OD $8.08 $48.48
3 Each 59985K19 Hi-Offset Slotted-Disc Set-Screw Coupling Hub 1/2" Bore, 1" Outside Diameter (Same as 59985K3) $9.72 $29.16
3 Each 59985K17 Hi-Offset Slotted-Disc Set-Screw Coupling Hub 1/4" Bore, 1" Outside Diameter (Same as 59985K3) $9.72 $29.16
3 Each 59985K63 Acetal Coupling Disc for 1" Outside Diameter Hi-Offset Slotted-Disc Set-Screw Coupling Hub $3.17 $9.51
1 Each 98837A033 Plain Steel Threaded Rod 1/2"-13 Thread, 3' Length $2.88 $2.88
1 Each 8982K374 Alloy 6061 Aluminum 90 Degree Angle 1/4" Thick, 2-1/2" X 2-1/2" Leg, 4' Length (Same as 8982K37) $34.23 $34.23
Merchandise Total $165.60
Yes Hack did a very nice assembly manual one of the reason i went with this design, that and from the illistrations i could see the pure simplicity of the design.. Thakns Guys
