603,359 active members*
4,661 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Unigraphics Extrude / sketcher
Results 1 to 5 of 5
    Dec 2007
    85
    Hello,
    I am trying to extrude the face of a solid but UG keeps putting me into the sketcher. I always use this method while making electrodes but a revision change has made this impossible.
    Does anyone know how to work around this?
    thanks
    g,
    Dec 2006
    77
    UG
    Use offset face. Otherwise, UG will send you into sketcher because there are no valid sketch curves in the workarea.
    Brian
    Dec 2007
    85
    puzzled.
    I am using the pick menu to select face but it still puts me in the sketcher. I am wondering if it's an error with my environment files. I will try it on someone elses tube here. Currently we have no other UG users in the building due to the "goings-on".
    oh..thanks for the reply.
    Feb 2006
    146
    What version of NX are you using?
    Set your selection intent to use Face Edges so the edges are selected and not the face.
    John Joyce -NC Programming Supervisor
    Barnes Aerospace, Windsor CT
    Dec 2007
    85
    Using NX4
    I was told to pick edge curve in the command but I can't seem to do that. I have found that if I set the selection menu and pick the element "before" hitting the extrude button works. I still struggle with extruding a face without going into the sketcher.
    cheers
  1. Unable to extrude along path
    By PeteGallo in forum Autodesk
    Last Post: 03-15-2008, 08:16 PM
  2. SW 2007 Extrude and chafer?
    By john_t_h in forum Solidworks
    Last Post: 03-11-2008, 12:20 PM
  3. Solid Extrude Cut Body
    By Mastercam User in forum Mastercam
    Last Post: 12-01-2007, 05:48 PM
  4. Extrude to multiple surface
    By Craigpat in forum Solidworks
    Last Post: 10-24-2007, 01:31 PM
  5. extrude slot at angle
    By PETE1968 in forum Autodesk
    Last Post: 04-11-2006, 02:01 AM
