603,932 active members*
2,865 visitors online*
Results 1 to 2 of 2
    Jan 2007
    14
    epoxy molding problem...
    hello...i am having a molding problem that seems to be a tough 1 perhaps some one out there can help me along ...I am casting electrical grade epoxy into a heated steel mold that containes wire leads that must run through the part .. Unfortunately the epoxy upon curing seems to seperat from the smooth surface of the wires causing oil to leak through under pressure when assembled into the transformer...if any of you out there have any possiabl solutions i would greatly appreciate it thanx
    Apr 2007
    777
    My instinct would be that there is a something vaguely oily on the wires keeping the epoxy from adhering properly. Have you thoroughly degreased the assembly before attempting to pot it?
    --Cameron
    Epoxy Nerd from the E/G thread
  1. Adding Metal Powders to Epoxy
    By JerryFlyGuy in forum Composites, Exotic Metals etc
    Last Post: 06-16-2011, 02:54 PM
  2. Greybeard's Epoxy/Aggregate cnc router
    By greybeard in forum DIY CNC Router Table Machines
    Last Post: 07-17-2008, 10:00 PM
  3. Epoxy/granite machine concept
    By Gizmot in forum Vertical Mill, Lathe Project Log
    Last Post: 02-28-2008, 09:46 PM
  4. Curing epoxy above room temperature
    By Syphonics in forum Composites, Exotic Metals etc
    Last Post: 05-28-2007, 10:11 PM
  5. Quartz filled epoxy...
    By karmicthre in forum DIY CNC Router Table Machines
    Last Post: 06-22-2004, 02:30 PM
