OK so here is my little idea. I want a machine with some good Z movement and really only want to machine high density foam (will use that as a male form on a vaccum forming machine). I really like the idea of building the frame out of extruded alumin. I know that the pricing will be on the high end but I think that this will be the "easiest" in my situation. I want to move the y axis up high and away from the mess and for stabiltiy? Plus I think it will be easy to quickly enclose this setup. The table is a 30"x30" and I think I should end up with about 25"x25" useable area. I want to mount the cutting motor (dremel or router?) so that when it moves up the z axis the do not have the support hanging down. Now my questions. What do you guys think of this idea? Do you think that the z axis will be stable enough for foam?
Here are some of my early ideas.
Carter
