587,822 active members*
2,897 visitors online*
Results 1 to 7 of 7
    Apr 2009
    28
    what's wrong with this layout???
    please see the attached image.
    it's stepper driver board: 2xL298 (parallel), with diodes and sense resistors, capacitor & connector.
    at first I made the small one, it work well (the yellow line is correction -> i forget to connect common ground) the problem is the space is to tight for L298's heatsink and big diodes.
    then I make it bigger, and the problem come...the motor now have noisy sound.
    color on layout:
    green = ground
    red = vss (24v)
    pink = vcc (5v)
    blue = L298 output for bipolar stepper
    where are the mistakes?
    Jan 2006
    738
    The green line and the pink line across the bottom are shorted together at the connector. Count from pin 1 of the input connector on both sides of the board.
    Steve
    Apr 2009
    28
    i re-check the circuit, the pink(vcc) and the green(gnd) are not shorted.
    if it's shorted, the circuit will not work.
    both layouts work, but the bigger layout causing my stepper motor having noisy sound.
    both layouts use the same component, except diodes.
    small layout use BYV27-100
    big layout use UF5404 (I have tried to replace it with BYT-56M but still noisy)
    btw, i replaced BYV27 diodes because it's IF.av is 2amp...can it handle 3amp?
    i have tried operating the BYV27 with 3amp current, but i'm affraid it will getting hot and break
    Jan 2006
    738
    I see, your top and bottom are not mirror image... Ok, How about your diode polarities? double check that.
    Apr 2009
    28
    diodes polarities are ok.
    finally i found the problem, it's not on this layout.
    I forget to put rc filter on sense line on the other board.
    btw, thanks vger for giving time to look my layout.
    Aug 2006
    132
    The different diodes seem to be the only variable not duplicated so...
    Can you post the schematic of this circuit or give a reference to it?
    "IT ≠ IQ " Starwalt 1999
    Apr 2009
    28
    vtxstar, the problem is solved.
    at first i thougt that the problem came from this board or layout.
    but the problem is on the other board (my L297 & L298 are not on the same board).
    on my other board (which contain L297), I forgot to put rc filter on sense line, that's why the noise appear.
  1. PDF Layout
    By alien_X in forum Uncategorised WoodWorking Machines
    Last Post: 01-07-2009, 12:10 AM
  2. Help with PCB layout
    By tajord in forum CNC Machine Related Electronics
    Last Post: 05-30-2008, 07:16 PM
  3. How do i layout an assembly?
    By genexis in forum Solidworks
    Last Post: 06-22-2007, 03:44 PM
  4. Layout Dye
    By mjarus in forum MetalWork Discussion
    Last Post: 12-31-2005, 06:06 AM
