Hello all,
I am a hobiest using Feature Cam to run a HURCO BMC 30 and a DAEWOO PUMA 8HC3A. I am just starting with the PUMA and I can say it sure is a different learning curve for the lathe than it was for the mill. The PUMA has a FANUC 15T control. I have been told to use the FANUC 11T post as I have been unable to find a POST for the 15T. My issue is that the G Code generated by Feature Cam puts the following line in the code in line 8.
G95G1Z1.2688F0.015.
The FANUC gets to this line and provides the following alarm.
PS010 which is Improper G-CODE.
How can I get the POST to generate this G95 on its own line?
