588,281 active members*
5,336 visitors online*
Results 1 to 3 of 3
    May 2009
    x2 Stepper motors
    Hay all, yes Im new to this forum. I finaly got my new x2 mill today. I want to convert it to cnc, my qestions are: Is the 23HSX-102 (1.9nm holding toruqe)steppers good for milling alluminium on the x and y axes and say maybe the 34HSX-104 on the z axes. Thanks.
    Mar 2008
    3655
    Hi ian21. Welcome to the Zone!
    That first motor would be about 270 oz. It SHOULD work, although other factors like what screws you use, PSU ETC. may affect it. Without knowing full motor specs I can't spec the PSU.
    This is what I recommend for X2:
    $289 G540 http://geckodrive.com/product.aspx?c=3&i=14469
    $098 Two $49 KL23H2100-35-4B 318 oz motors for X & Y
    $049 One KL23H284-35-4B 387 oz motor for Z
    $060 One KL-350-48 48V/7.3A power supply.
    $010 Estop switch
    $007 3 Home switches
    $009 Straight thru parallel computer cable.
    $522
    All of this is available from Keling and he ships internationally--email for quote:
    http://kelinginc.net/
    CR.
    May 2009
    Your Hobby CNC Information Resource!
    Make Homepage | Add To Favorites | Print Page | About Us
    Navigation:
    Home / News
    DeskCNC Direct
    Mach Direct
    Stepper Direct
    Control Direct
    Linear Direct
    Inverter Direct
    Profile Direct
    Electric Direct
    Servo Direct
    Motor Direct
    Accessories
    Links
    Ordering
    Contacts Details
    Featured Articles:
    Power Supply Design
    Our Programs:
    Quick Links:
    People have
    visited my page!
    CNC Direct > Motor Direct
    < Return to Home | Articles |
    Motor Direct
    Stepper & Servo Motors
    NEMA 23 STEPPER MOTOR:
    These are new, state of the art, bipolar 4-wire stepper motors designed and built with the newer high performance technology.
    Part Number Holding torque-Nm
    +/- 10% Rated voltage Rated current per phase amps (DC) Resistance (Ohms)
    +/- 10% Induction (mH) +/- 20% typical Motor
    length (mm) Weight (kg)
    23HSX-102 1.9 3.75 2.8 1.3 5.7 80 1.0
    23HSX-203 3.5 3.00 3.0 1.2 4.0 100 2.1
    23HSX-102 Price
    R1195.00 Ex-Stock
    23HSX-203
    Price
    R1695.00
    Ex-Stock
    NEMA 34 STEPPER MOTORS:
    These are new, state of the art, bipolar 8-wire stepper motors designed and built with the newer high performance technology.
    (Volts) Rated current
    per phase
    (amps DC) Resistance (Ohms)
    length
    (mm) Weight
    (kg)
    Series Parallel Series Parallel Series Parallel Series Parallel
    34HSX-104 4.2 3.7 1.8 3.5 7.0 1.06 0.26 4.8 1.2 65.5 2.2
    34HSX-207 6.8 4.3 2.2 3.5 7.0 1.24 0.31 8.0 2.0 78.5 2.2
    34HSX-309 9.1 4.4 2.2 4.0 8.0 1.04 0.26 8.0 2.0 91.5 2.2
    34HSX-104 Price
    R2295.00 Ex-Stock
    34HSX-207 Price
    R2695.00 Ex-Stock
    34HSX-309 Price
    R2995.00 Ex-Stock
    Check-out [Stepper Direct] for the G203V Stepper Motor Drives!
    Check-out [Electric Direct] for suitable power supplies!
    NEMA 34 SERVO MOTOR:
    Brushed, permanent magnet with 2000 pulse/rev encoder.
    Part Number Continuous torque-Nm (oz/in) +/- 10% Max torque-Nm (oz-in) Rated voltage Rated current (A/Nm) Resistance (Ohms) +/- 10% Induction (mH) +/- 20% typical Encoder pulses/rev Rotor inertia (g-cm^2) Weight (kg)
    34HDX-101 1.2 (176) 6.0(882) 72V 1.75 85 2.35 2000 3.39 4.5
    34HDX-101
    Through Shaft
    (1/2" + 1/4")
    Price
    R3195.00
    Check-out [Servo Direct] for the G320 and G340 Servo Motor Drives!
    Please see our ordering page for conditions of sale.
    Ordering Info
    South Africa's only online Automation Warehouse
    Have any questions or comments?
    Contact Us. Running 2004-2008 Hobby CNC.
    Last Updated: 11/03/2008 08:59:09
    Thanks for the reply. Hope this will help you identify the motors. It will be belt driven.
  1. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
  2. stepper motors or servo motors?
    By jprobst in forum Torchmate
    Last Post: 07-13-2007, 11:37 PM
  3. Stepper Motors ???
    By droddis in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 10:54 PM
  4. Stepper Motors
    By Bob Cole in forum DIY CNC Router Table Machines
    Last Post: 12-31-2005, 10:16 PM
  5. Stepper motors...
    By Mikael in forum Stepper Motors / Drives
    Last Post: 09-14-2004, 10:41 PM
