587,744 active members*
2,864 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Work Fixtures / Hold-Down Solutions > Inexpensive vacuum work holder for my cnc router
Results 1 to 5 of 5
    I put together a pretty good vacuum hold down for about 100.00
    The details can be found here: http://www.lockeconsulting.com/lockeblog/?page_id=132
    Oct 2009
    272
    Does this SUCK, or what!!!
    I really like your discovery. The plastic is cheap enough that one can make several different sizes/patterns to fit various/unique projects. Great use of cost effective, readily available items. A true DIY solution. Thanks for posting.
    Randy,
    I may not be good....
    But I am S L O W!!
    Mar 2008
    377
    how would this work if you have a smaller pc than the vacuum plate
    Sep 2005
    540
    Nice posting, thanks for the tip on using shelf-lining material. Funny thing is I have rolls of that stuff sitting around but never thought to use it in a vaccum setup.
    Thanks,
    Robert
    Sep 2010
    528
    How many people have used this solution? Would you share your results?
    Thanks,
    James
  1. Hitachi Router Holder ???
    By biotech1 in forum Joes CNC Model 2006
    Last Post: 09-06-2009, 05:53 PM
  2. Recommended best inexpensive design software to work well with R2E4???
    By europe50 in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2009, 06:37 AM
  3. Work Holder Definition
    By MAX711 in forum SprutCAM
    Last Post: 12-14-2006, 12:38 AM
  4. How do vacuum chucks and vices work if all the holes aren't covered ?
    By bobJandal in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2006, 05:01 AM
  5. Here's some good information on making work holddown vacuum pods
    By buscht in forum DIY CNC Router Table Machines
    Last Post: 01-31-2005, 07:22 PM
