587,402 active members*
3,037 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam 4-axis
Results 1 to 10 of 10
    May 2009
    Mastercam 4-axis
    Hello, this is my first post. Hope I'm doing this right.
    Anyhow, I have two mastercam 4-axis problem. First one is that when I post the 4-axis toolpath I get the correct x and y coordinates for 2 out of the 4 sides that I am machining. The 2 incorrect x,y coordinates are the exact opposite as the correct coordinates. An example would be, the correct x coordinate would have a positive value, and the incorrect coordinate would have a negative value. The same goes for the y.
    The next problem is, instead of getting a, A90.,A180.,A270., or A0.0, I get G54,G55,G56 and G57. I have the rotary axis turned on. I've tried messing with tool planes and construction planes, but no luck. Could use some help.
    Thanks,
    Bob
    May 2006
    99
    I bet the 2 wrong axis's are the bottom and the back!
    Take a piece of paper and draw your axis's on it. Now turn the paper in the direction your 4th axis turns. Now you see the axis's don't match your machine's axis's. Therefore you need to make 2 new World Coordinate Systems ( WCS) for bottom and back. If you want all of your WCS have the same Workoffset ( only G54 or whatever your machine uses) then you set these in the WCS under origin. So if you only want G54 for all sides set all WCS origin that you use to 0 ( zero )
    Now 1 thing I have learned with 4 axis is that your origin always needs to be in the center of your part which also is the center of your 4th axis!
    I have had trouble with it in the pass. Looks all good in mastercam but not when machining.
    Tip: Get Mike Mattera's dvd's from www.tipsformanufacturing.com
    I bought the combo mill package and must say there real good.
    Good luck with your 4th!
    Apr 2003
    3578
    Actully you want to make new planes you can do this by making new WCS but do not set the WCS but use Plans then go to Named Views. review picture.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    May 2006
    99
    So by picking the named plane instead of the WCS you create a new plane but stil with the same WCS as the one you reference from?
    Guess I've been doing it all wrong then.
    Thanks!
    Mar 2009
    Quote Originally Posted by Stebedeff View Post
    Not necessarily wrong, just different. One thing I have learned, there are many ways to get it right and even more ways to get it wrong.
    It is not essential to have the origin at the center of rotation, just simpler.
    Sometimes it is a good thing to output a different work coordinate for each rotation, so each face can "tuned in " independently.
    I used to move the part to center of rotation. Now I do as CADCAM suggests and make a new WCS with the top view looking at the pallet (down the axis of rotation).
    This makes it nice if the customer makes a change and you get a new model, you can just import it without having go move and reorient it.
    Some times the post will even need a tweak to get the 4th axis output the way you need it.
    Jun 2009
    15
    New planes worked but,
    Thanks for the info about creating and using the planes, it worked for getting the correct x and y coordinates but, still getting the g54,g55 etc. Any more help would be appreciated. Also, would like to know how to tweek the post so that it spits out a m13 (to unlock) before the a90 command and a m12 (to lock) after. I found the rot_loc in the post and changed it to 1, and changed slock to m12 and sunlock to m13, but still not posting correctly.
    Thanks to all that responded to this post, it was of great help.
    Bob
    Apr 2008
    6
    Milspec,
    Did you ever figure out how to get it to stop changing to G55, G56, etc went you want only G54? I am having the exact same problem.
    Apr 2003
    3578
    leftcoastlefty , what version of MC an do you have a file you are having issues with that you can send me?
    Cadcam
    Nov 2005
    244
    To force out (1) G54 or work cordinate try: parameter, planes, check on work offset box, then input 0 for all your work planes.
    Jun 2009
    3
    HELLO I AM OF BRAZIL AND THE COMMUNITY ABOUT THIS POST CNC ALSO I HAVE PROBLEMS WITH 4 AXIS I wish SOMEONE SEND ME THE POS 4 AXIS MASTERCAM V8 / 9 Heidenhain FROM .. thank you ... [email protected]
  1. W axis on Mastercam
    By Goran P. in forum Mastercam
    Last Post: 02-25-2009, 02:16 PM
  2. Mastercam x c-axis problem
    By Mike68 in forum Mastercam
    Last Post: 11-20-2008, 02:21 PM
  3. mastercam postprocessor 5 axis
    By pgman68 in forum Post Processor Files
    Last Post: 05-07-2008, 02:26 AM
  4. 4th Axis Toolpath with mastercam
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 01-07-2007, 03:41 AM
  5. does Mastercam support 5 axis ?
    By Calico in forum Mastercam
    Last Post: 05-03-2005, 09:08 PM
