587,357 active members*
3,817 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > chnc I turret up problem needs a clue
Results 1 to 3 of 3
    Aug 2007
    31
    having problem with turret up for turret to index turret trys to go up but slow
    or no pressor a little help up with allen key, then it indexes to next station . changed stop valve and quad/orings in valve block , changed turret up valve, no change hear air blowing when turret trys to go up , need a clue
    Oct 2009
    51
    On CHNC's there are a good number of seals/ o-rings that are in the many parts of the turret. Chances some of these, or possibly just one, is allowing air to flow to a part of the machine it shouldn't. I work on Harding equipment all the time. when these seals leak, the turret either raises and indexes but never seats, delayed/slower indexing times, and louder air leaks. Im a service tech for a midwest distributor of Hardinge equipment. Hardinge has a sales seal kit for CHNC's you should find your dealer around u and get one of these on order. Then pull out your part list and you can figure out where they go and how the turret is assembled.
    Jun 2004
    84
    Quote Originally Posted by Nawrocki4Life View Post
    Correct, after 12 yrs on my bought new CHNCI that started, a new turret o-ring kit fixed it. Lots of seals & rings in that kit.
  1. HAAS SL-20 TURRET PROBLEM HELP
    By allmotormatt in forum Haas Lathes
    Last Post: 01-20-2011, 06:47 AM
  2. Hardgine CHNC II turret problems
    By CatesMetal in forum Bridgeport / Hardinge Mills
    Last Post: 08-29-2009, 01:14 AM
  3. CHNC II GN10 control Initial start up problem
    By LeftCoastCNC in forum Hardinge Lathes
    Last Post: 07-14-2009, 04:00 AM
  4. Hardinge CHNC turret woes
    By Karl_T in forum CamSoft Products
    Last Post: 12-19-2006, 10:54 PM
  5. SL 10 turret problem
    By PBMW in forum Haas Mills
    Last Post: 08-16-2006, 02:51 AM
