603,882 active members*
4,731 visitors online*
Results 1 to 3 of 3
    Jan 2007
    142
    Hi guys
    Is it possible to machine undercuts using SolidCam without pivoting? I only have a 3-axial machine.
    I have to machine the V-groove of the following unit. Unfortunately it has an angle of 98°. I wanted to mill by line with a prism cutter (90°).
    [attachment=5402:Modell.jpg]
    Does anyone have an idea how I should make it?
    I’ll appreciate any tip!
    Greetings
    High Speed
    Paranuit Guest
    Hello Christoph
    I made that with 3D surface editing.
    I used a prism cutter DM 60x20x90°.
    Prism surface as editing mode and upper line as manipulation geometry.
    Covering 0,5.
    Jan 2007
    142
    Hi Paranuit
    I can’t get it somehow…
    Could you make a couple of screenshots?
    I believe I’m just too stupid.
    How did you define the tool? Maybe that is the problem.
    High Speed
