Hi guys,
I work with machines that can take 2Ds .dxf files. (Acurite MillPwr and Mazak via camlink)
It works very well. I give them .dxf of contours and points so I don't have to programm everything.
Problem is a client sending models in Catia V4 (.model)
I have hard times trying to convert the .model files to 2D contours then to .dxf
I have Catia V5, Mastercam 9 and Autocad 2004.
I open the V4 models in Catia V5 but can't edit, not even save in any format!
So I copy the part and paste it in a fresh V5 .catpart window.
From there, I still can't edit but I can save it in .igs format.
Then open it in mastercam (that have a .dxf converter) but I can't edit anything once in mastercam.
I can't even select the part and when I save it in .dxf, Autocad doen't show it in the screen.
What a hell, I just want to convert the .model in .igs or .dxf or .dwg that I can edit/put in 2d wireframe.
Any idea ?
Note that I can open the .igs in catia and erase faces but it's still not a wireframe.
Maybe I just have problems converting to wireframe
Thanks in advance
